Hi Fellow CTS-V owners!
Are you looking for a spare tire kit??? https://modernspare.com/
OUR PACKAGE INCLUDES:
To make our kit incredibly simple to use, we began by designing an aluminum alloy wheel that is significantly lighter and more capable than its conventional steel counterpart. This makes it much easier to handle and improves vehicle performance & fuel economy. To maintain excellent standards of quality, we ensured that our alloy wheel meets or exceeds the latest DOT standards. To make storage and transport easy, we designed a custom carrying case constructed with durable high strength material that is reinforced by interwoven nylon straps. This allows users to comfortably transport and store the kit at home or in the trunk of a vehicle.
For more info please visit our site: https://modernspare.com/
- Heavy Duty Modern Spare Complete Kit Carrying Case With Storage Pocket For TruLift Ratcheting Scissor Jack & Telescoping Lug Wrench
- 18x4 Aluminum Alloy Wheel With 5x120MM Bolt Pattern. Maxxis T155/70R18 Tire W/81 MPH Speed Rating (112M) - 26.5? Rolling Diameter For Safe Extended Vehicle Use.
- Enlarged Wheel Brake Caliper Clearance For Use With Large Modern Brake Systems. Safe To Use For Replacement Of Front & Rear Tires With No Spacer Required.
- 3000 LB TruLift Ratcheting Scissor Jack With Rubber Contact Point. Modern Spare 14? - 21? Telescoping Lug Wrench With 17MM, 19MM, 21MM, & 22MM Sockets.
- Large Disposable Tire Bag Included For Full Size Tire Transport
